Oil Pump Repair Kit
Paul Sisk
06-02-2002 18:41:05
I have a 1952 Farmall Super C and the oil pump gears are considerably worn. I have not been successful in locating a source for a repair kit. I would appreciate any guidance.
Thanks.
RPM
06-04-2002 06:25:00
 Re: Oil Pump Repair Kit in reply to Paul Sisk, 06-02-2002 18:41:05
Other than obvious wear to shafts/gears, this pump has a pot metal cover that warps and leaks pressure, check it for flat surface where it bolts on pump housing, new pump from Case-IH is $446.00
Gene
06-03-2002 12:11:41
Paul: Look below about half dozen posts to the one about First 806 built. "Bermuda Ken" is the man to get parts from for older Farmalls. Their an IHCase dealer. G
