Re: Super A with Steering Reservoir Leak
BIG JOHN
05-30-2002 13:57:02
A lot of the guys have quit trying to use gear lube because it is so hard to keep the steering gear housing from leaking. Instead they fill the housing with gun grease. This works well unless you use your tractor in very, very cold conditions and then it might be a little stiff.
Hugh MacKay
05-30-2002 17:19:26
 Re: Re: Super A with Steering Reservoir Leak in reply to BIG JOHN, 05-30-2002 13:57:02
That is what I use John, put a grease fitting in oil level hole just under steering shaft. I put a full tube grease initially and since that I give it a few shots every time I grease tractor. Works very well and no more mess. You have to get resovoir full of grease, as grease will not necessarily go to gears unless it has nowhere else to go. I live in cold climate, it is not bad.
Brad Harper
05-31-2002 05:25:11
 Re: Re: Re: Super A with Steering Reservoir Leak in reply to Hugh MacKay, 05-30-2002 17:19:26
Thank you Hugh. I will put a grease fitting on and fill with grease. This appears to be the easiest fix and still provide needed lubrication.
Brad Harper
06-12-2002 17:25:44
 Re: Re: Re: Re: Super A with Steering Reservoir Leak in reply to Brad Harper, 05-31-2002 05:25:11
I put the grease fitting(zerk) and loaded it with grease. Works like a charm!!! The CIH dealer had a grease fitting that fit the level check plug...Thank all of you guys for your posts... You saved me lots of headaches!
