706 Running Again, but?
Farmall Don
05-25-2002 18:15:03
After replace of the #6 melted piston and a complete valve job, I have the tractor running again. After driving it a half mile or so I stopped & noticed that it has a little bit of white smoke coming out of the breather. Is this normal for a break-in period or could I have another problem? I honed out the sleeve and put in a new piston & rings. The machine runs great.
It has 500 hours on the complete overhaul and the sleeves had .002 to .003 wear and the other pistons rings measured good.
Ken T.
05-26-2002 05:16:27
 Re: 706 Running Again, but? in reply to Farmall Don, 05-25-2002 18:15:03
White smoke is a sign of water in the combustion chamber. At best it is due to condensation in the engine from not being run for a while. Most likely, however, you are getting coolant in the combustion chamber due to a leaking head gasket or a crack in the cylinder head.
Farmall Don
05-26-2002 11:01:04
 Re: Re: 706 Running Again, but? in reply to Ken T., 05-26-2002 05:16:27
Went back out and warmed up the tractor again. The head bolts had loosened up and also the valve gaps were screwed up (both set cold). It seems this has solved the problem or it was just condensation at first.
Thanks
