Front end alignment?
Author |
Randy
05-17-2002 05:39:40
On a wide front end tractor should the front wheels be lined up parallel with the back wheels or should they be toed in a little? Any toe out I think would be bad. Also how do you check for problems with front spindle bearings?
the tractor vet
05-17-2002 09:01:26
Re: Front end alignment? in reply to Randy, 05-17-2002 05:39:40
Yes there shoud be toe in on them and you check that at the center line of the spindel in the center of the tire tread ft. and back anywhere of 1/8th inch to 3/16th of an inch. would be good and to check spindel slop like the other guy said jack up the ft end and use a long pry bar and move it up and down and side to side , i am sure that you will find that the bushing are wore since it is not a new one and you can replace the top and bottom bushing and thrust bearing on the bottom but it will not get it all out unless you replace the spindels and that will get a bit pricey remember it is only a tractor and not a race car some slop is allowed.
scotty
05-17-2002 06:45:41
Randy, Front tires should be slighty toed in. You can check bearing slop by jacking front end up and grab tire top and bottom to see how much movement you have. If it is minimal you may only have to repack grease in bearings. scotty
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains?
... [Read Article]
Latest Ad:
Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
