Re: Bull pinion/brake shaft
Mike ISW
05-17-2002 04:11:23
I just did what you descroibed to my '48 H. First of all don't try to remove those pinion housings yet. They wrap around the bull gears. The trans/diff cover needs to be removed and then you can remove bull gears. To get pinion housings out you'll see 2 threaded holes in each...use the retaining bolts in these holes to remove housings. I've heard guys on here remove bull gears from PTO opening without removing deck but you then don't get a good look at what else may be bad in trans/diff. re-post if more questions.
