Farmall super c/lights,hydro fluid and exhaust
steve
05-10-2002 06:37:46
have good connections and bulbs are good...then i find a place for fuse that is packed with dirt. is this for the lights? also...which postion is which on the charge/lights switch? i am discharging while tractor is running and am trying to pin point the problem. waiting on service manual so am kind of winging it right now....also, what kind of hydro fluid to use and how to check proper level? just put new pipe for exhaust in manifold...what is the actual height of this supposed to be?
RedTed/MO
05-11-2002 04:04:00
 Re: farmall super c/lights,hydro fluid and exhaust in reply to steve, 05-10-2002 06:37:46
steve: However long the exhaust pipe from the manifold was on these Super Cs coming from the factory,... it wasn't quite long enough! The muffler and clamp then ended up right close to the hood: first of all, a little hard to work with; secondly, the hoods took some abuse at that point. Redoing my own SC,... I've elected to extend that pipe a couple of extra inches. RedTed/MO.
SAm in NS
05-10-2002 12:56:47
I'm fairly certain that that fuse is for the lights. Good luck. SAm in NS
Daniel
05-10-2002 12:19:08
The fuse is for the lights. Should be a 20A fuse.
Farmer Bob
05-10-2002 08:00:08
Steve, If you have a three position light switch the fully counter-clockwise is off, then Dim, then bright going clockwise. If its a 4 position switch, fully counter clockwise is low charge, then high charge, then Dim, and finally Bright lights.
I always use HyTran hydro fluid from my dealer and the bood says proper level with all the air out of the system and the rock shafts in the fully retracted position (Toward the rear) is 1/2" below the bottom of the fill plug.
As far as the length of the exhaust pipe, can't be sure but I'd say at least 8" maybe someone else can get you right on with this. I believe the SC had a longer pipe because of the difference in height of the grill and gas tank./FB
