Final Drive Unit
Dwight
04-30-2002 19:15:47
I have a 48 Farmall Cub. The I&T Shop Service manual shows that each Final Drive unit holds 1 and 3/4 pints of lubricant. Where do you check the fluid and how do you add any if needed?
Merlin
05-01-2002 00:26:35
 Re: Final Drive Unit in reply to Dwight, 04-30-2002 19:15:47
Dwight, there is a 1/2 " female plug on each final drive housing that a 1/2 " drive ratchet will fit. Take the plug out and fill to where the oil starts running out from around your funnel. That means its full and at proper level.
Farmer Bob
05-01-2002 19:50:26
 Re: Re: Final Drive Unit in reply to Merlin, 05-01-2002 00:26:35
Merlin, Thanks for correcting me. Upon closer inspection on mine I see the plugs. The side I looked at (Left) it was behind the drawbar bracket. I stand corrected.//FB
Merlin
05-01-2002 22:20:45
 Re: Re: Re: Final Drive Unit in reply to Farmer Bob, 05-01-2002 19:50:26
Thats allright Farmer Bob, you probably know a hundred times more about tractoring than I do. I've been using the same Super A since 1950 thinking I knew all about it. Come to find out when I got this computer that I didn't know nothing at all about it.
Farmer Bob
04-30-2002 22:26:20
There is no check plug and the only way to add is to remove all the bolts and lower the pans on the bottom to add the lube. Prolly a good idea to do this anyway as condensation likes to collect down there over a winter season.//FB
