Re: framall m
Kenny
04-18-2002 12:57:32
I would first check to make sure you have hydrolic fluid in the belly tank. If there is fluid there, you may have a bad hydrolic belly pump or a bad cylinder on the 3pt., if you only have one cylinder. You may try and move the hydrolic hose to another hydrolic output. More info on the 3pt. will help more. Do you have one or two cylinders on the 3pt.? If you run the tractor long without hydrolic fluid, there is a great chance the belly pumb will go bad.
