MD stuck
jim
08-06-1999 20:52:09
i am working on an md as well as a wd9 the md is stuck. VERY stuck any ideas
Corn bread Red
08-08-1999 22:23:52
 Re: MD stuck in reply to jim, 08-06-1999 20:52:09
Pull the head, fill the holes up w/brake fluid make a wick out of an old sweat sock,lighter off and let burn all afternoon do it again then try alittle perswation w/ a big maul. I go down to the brake shop and get disc brake pistons about the same size as the bore and use these pucks to beat on . beat carefully
Wayne
08-07-1999 02:55:20
Pull the spark plugs and and put some Marvel Mystery oil in the cyls. and let it work for about a week. Good Luck.
Skip
08-07-1999 20:25:28
 Re: Re: MD stuck in reply to Wayne, 08-07-1999 02:55:20
To make this work you must have the "gas, diesel" in gas position.
TMAC
08-07-1999 16:04:59
I too had a stuck MD. The head was off and I sprayed BREAK AWAY on each piston sides and placed a round piece of hardwood in each cylinder and banged away with a 5 lb. sledege hammer. I did this some on each piston, sprayed again, then let it sit for another day. This went on for weeks. When one piston appeared to move, I would work on the others. Keep the pistons wet with whatever type of 'loose juice' you have.
