'50 H Front End Fix
Author |
Krey in Indiana
04-08-2002 10:35:11
I know this has been posted before, but I've searched the archives and can't find the info I need. My '50 H steering is quite loose. The U-joints are tight and the sector and worm gear look good, so I guess it's time to rebuild the front end. Can anyone please post a brief step-by-step for removing and rebuilding the front bolster (it leaks oil like a sieve, so it's full of grease now). Also a list of any parts I'll need would be great. Thanks in advance for any replies. Krey Milltown, Indiana
Bleedinred
04-08-2002 19:49:06
Re: '50 H Front End Fix in reply to Krey in Indiana, 04-08-2002 10:35:11
My bolster shaft was worn bad enough I had to have it turned down and bushed on both ends. Cost $90 but fits like new. Funny thing the lower brass bushing wasn't worn enough to warrant replacement.
Farmall-Man
04-08-2002 17:36:06
I just finished re-doing the front-end on my H. To get the sector gear loose, I jacked up the tractor under the clutch housing - after blocking the rear end so it wouldn't roll, then loosened the nut on top of the sector gear. Leaving the wheels and lower bolster on for weight, I sat a block of oak on top of the sector nut and whacked it with a hammer. About two whacks, it broke loose. I then took the lower bolster and wheels off and removed the shaft out of the upper bolster. At this point, I cheated a little as I needed to repair the radiator also - I took the front bolster off and worked on r/r the bushings and seals while it was laying down. That made the whole repair a whole lot easier. Good luck on yours. FM
willaimf
04-08-2002 14:42:52
I just did my H a few weeks ago. You'll probably want to replace the thrust bearing and spacer while you've got it apart. Those bushings can be a pain; I took an hour and a half to get the top one out. Decided the bottom one looked good. I researched getting the sector gear loose from the upper bolster on this site's archives; a lot of ideas, none of which I had the right equipment for. I&T manual says,"Using an appropriate puller..." I didn't have that,either. What I wound up doing was leaving the wheels on while I jacked it up, for weight and to catch it, and using a puller with chains to push the shaft. Then I hit the top of the puller with a small sledge.
The Red. WOW
04-08-2002 15:08:15
Re: Re: '50 H Front End Fix in reply to willaimf, 04-08-2002 14:42:52
Thanks for the pictures. Got them saved because I have a front end to do on Old Red H.
clif bice
05-18-2003 18:41:32
Re: Re: Re: '50 H Front End Fix in reply to The Red. WOW, 04-08-2002 15:08:15
Could you send me the pictures of the repair on the h? Thanks
Hump
04-08-2002 14:15:10
Jack up tractor,remove front wheels and lower bolster.Put jack under upper bolster,remove worm gear and sector,let down upper with jack.Replace seals and bushings,upper seal is hard to get at,be careful to start it straight
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the
... [Read Article]
Latest Ad:
Rebuilt 1979 Ford Truck Rockwell Rear axle. This axle will also work as the rear axle in a tandem set up. This is out of my F700 and is a single speed. Rockwell with 6 hole wheel lugs.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
