Re: OUCH!!! Sheared bolt!!!
Farmer Bob
04-07-2002 18:10:24
Tim, It may be easier to remove that whole casting from underneath the tractor to work on getting your broken bolt out. Take a correct sized socket and a quality breaker bar preferably a 3/4"drive and you will be able to remove the three large bolts holding the casting to the bottom of the torquetube. Once its off then you can work at drilling out the broken off bolt for the pin retainer.
