Super MTA Hyd system
BEL
03-24-2002 17:13:45
I was looking at a 1954 MTA and the hydralic system looked like plumbers nightmare of 1/2 inch pipe. The owner says it is factory original. Can this be true? As usual thanks in advance.
KURT
03-25-2002 02:57:11
 Re: Super MTA Hyd system in reply to BEL, 03-24-2002 17:13:45
You should have hoses to the valves and cylinders (not ridgid pipe)
Bob M - like this? (link to pix)
03-24-2002 18:57:58
Does it look something like this? Punch below for a "factory" Super M live hydraulic with an added Charlynn power steering flow divider valve.
mjd
03-24-2002 19:40:27
 Re: Re: Super MTA Hyd system in reply to Bob M - like this? (link to pix), 03-24-2002 18:57:58
Is it difficult to get the live hydraulic set up to a Super M instead of the "lift-all" that is already on? You have to get a live pump for up by the distributor, right? Where can a person get them things, and cost is ??
Thanks..... ...
mjd
Steven@nd
03-25-2002 08:52:02
 Re: Re: Re: Super MTA Hyd system in reply to mjd, 03-24-2002 19:40:27
Unless you can find the M&W pump it can get expensive and labor intensive. To mount the IH pump from a Super M through 450 you need to change the timing cover and cam gear. Expect to spend $500 on it.
A better idea is to weld another pulley on the crankshaft and mount a pump to the side of the tractor. It is cheaper.
Steven
PaulH
03-25-2002 10:43:04
 Re: Re: Re: Re: Super MTA Hyd system in reply to Steven@nd, 03-25-2002 08:52:02
Steven, could you explain a bit on how you would add a pulley? Are you welding it to the front of the existing pulley? Is there still room to squeeze belts on? Seems awful tight in there!
Steven@nd
03-25-2002 11:26:41
 Re: Re: Re: Re: Re: Super MTA Hyd system in reply to PaulH, 03-25-2002 10:43:04
Here are some pics of a cogged drive pulley on an H. It can be done. Local machine shop has an H with a loader on it with a chain drive pump driven from the crankshaft - I think it is a #50 chain.
Steven
third party image
third party image
Ron
03-24-2002 18:44:35
Without the two way hydralic valve, you should have two hoses, one presure and the other one supplies the oil to the pump.
