Belly mount sickle mower
Farmall from mi
03-11-2002 18:41:22
Does anyone know if a belly mount sickle mower from a 140 will fit an A?
Thanks for the help
Curt Cooke
03-12-2002 06:15:58
 Re: belly mount sickle mower in reply to Farmall from michigan, 03-11-2002 18:41:22
Wait a minute. Depending on which model mower, you may have other problems. Be aware that the mounting holes in the bell housing are different on the 140 than on the A. If part of the mounting of the mower involves the bell housing watch out for this. The 140's holes are upper left and lower right; the A's holes are upper right and lower left (or the other way around).
Curt Cooke
03-12-2002 06:16:25
Hugh MacKay
03-12-2002 01:27:26
Yes it will, the only problem you may have is if 1 of the tractors had Fast Hitch and the other didn't. The mount for the lower pully is slightly different. May need some minor fabrication.
