Spreader needed!
Darren Pulket
03-10-2002 16:50:39
Hey there guys i need myself a spreader and i'm a International Farmall guy so i wanted a red spreader i got myself a 9 month old bull and he makes some manure and got a big garden plus to help farmer spread. Id like one under $2-$300 and i live in PA near lancaster county
RayP(MI)
03-11-2002 17:22:36
 Re: Spreader needed! in reply to Darren Pulket, 03-10-2002 16:50:39
Based on the rear end it looks lots more like a Deere than a New Idea! They are the only ones I know that used an auger instead of paddles to spread.
Tim Malin
03-10-2002 22:06:21
Hey, if you buy that spreader on eBay for 50 bucks, you drive down or over to RI and pick it up, you might have a total of 100 bucks invested in it between gas, time of travel, and purchase. I believe it is an old McCormick No. 20, so I would go ahead and bid. For 5.00 you can't go wrong, man, even if it needs a little TLC. Good luck.
One on ebay now !!!
03-10-2002 20:16:09
Attached a link to a spreader that is on ebay, looks like it may sell cheap. On one has bidded on it as of this time, and the seller did not set any reserve on it.
Problem is that it is located in the Providence, RI area.
May or may not be what you are looking for.
Opening bid is only
03-10-2002 20:19:18
 Re: Re: Spreader needed! in reply to One on ebay now !!!, 03-10-2002 20:16:09
$5.00
may be worth checking out.
1PWRFULH
03-10-2002 18:09:13
We bought an Oliver Superior spreader for our 3 horses this past fall for $100. It's old, ground driven, and works like a new one. The guy that had it oiled the bed every year. The chains and sprokets all look like new. Just figured I'd tell you that you can get an old cheap spreader that will work just like new. Good luck.
1PWRFULH
03-10-2002 18:09:10
jerry gerthofer
03-10-2002 17:22:42
can not get much for $200to $300..... .....
