Re: 350U clutch plate ID help
Salvage Man
03-06-2002 08:01:59
I grind a lot of flywheels off of tractors that have had a button clutch and a woven disc. The only difference between the two types of clutch's is the flywheel that had a woven disc looks better when you take the clutch off. When you grind the flywheels the amount that is removed is about the same. Also a button clutch lasts longer than a woven clutch. If I can get a button clutch for an IH tractor I will put it in. And I also recommend that everyone else do the same.
