Farmall B conversion to A
Dave G
03-05-2002 17:04:00
Hello - I am building a Farmall B and want to make an A instead. What all do I need? If I get the A front Axle is that all I need to do? Will the tin and steering wheel shaft all work? I got the rear end converted already (removed the left axle extension).
Thanks for any help. If anyone knows where I can get an A front end in Iowa let me know too.
Thanks again.
Mr Obvious
03-06-2002 06:34:27
 Re: Farmall B conversion to A in reply to Dave G, 03-05-2002 17:04:00
Why not just BUY an A Farmall?????
Dave G
03-06-2002 18:32:20
 Re: Re: Farmall B conversion to A in reply to Mr Obvious, 03-06-2002 06:34:27
All the differences weren't Obvious to me that is why I was asking.
Dave G
03-06-2002 18:04:57
Because I have lots of parts and not lots of money. I like working on tractors too.
gene b
03-06-2002 04:56:05
removing the left axle does not make it an A the As axel is shorter than a B by 4ins you need the whole front steering housing and axle steering shaft 350 was the going price in your area is your B front assy good I might trade with you you can e-mail me live sw IA CITY 17MI
Vern
03-05-2002 21:49:55
You will have to change the front of the engine that contains the steering box and axle mount.
Tin and steering shaft should work.
big fred
03-06-2002 00:36:34
 Re: Re: Farmall B conversion to A in reply to Vern, 03-05-2002 21:49:55
The lower grill is different. Also, the axle on the B is not the same as an A, you want to start with a BN. It will probably work fine, though. The operator platform on the A is the same as a BN also, 4 inches narrower than a B. In addition, make sure you always keep a wheel weight on the right wheel, unless you are going to put on the heavy cast wheel center from the A.
MD Wa
03-05-2002 21:48:30
Dave You might want to rethink this project. Per the parts book you will need the compete steering gear housing and all that goes with it.(not steering wheel)Other words the only thing you can use is the steering and the 1st key and maybe the bolts that mount housing to engine. A is diffent from AV and B and BN are diffent from the 1st two. LOL MD
John Blanc
03-06-2002 04:45:57
 Re: Re: Farmall B conversion to A in reply to MD Wa, 03-05-2002 21:48:30
Doing both an A & B is probably cheaper (and easier)in the long run.
