Re: IH 1466
TBear
02-28-2002 18:46:37
Sounds like it could be a suction leak.Did you put a new o-ring on when you changed the filter?The old ones can be stretched a little and pinch when you put cover back on and cause a leak.I've had that happen and the symptoms were the same as you describe.The front cylinders leaking down is likely a separate problem.The seals in the cylinders are bad or there is a problem in the valve.Hope this helps. T
