Re: Giving up on Farmall M
The Red
02-26-2002 06:27:20
I searched the archives to see what other posts you had on the M clutch questions. Other than some wobble with the shaft through the clutch housing casting, are you having problems with engagement?
redrev
02-26-2002 06:36:32
 Re: Re: Giving up on Farmall M in reply to The Red, 02-26-2002 06:27:20
When the pedal is pushed down, it only disengages about 1% of the time. I often have to start it in gear to play with it, and that isn't too smart! A new clutch was installed when the guy restored it and the flywheel was even turned. I think he didn't get it in or lined up right, but I just can't find anyone to fix it, and the next time I get "down on the ground" it will be in a box. I'd do it if I could, because I really like the tractor. If you click the link and see the pictures, you'll know why. I can't believe the fix it that difficult, but I can't find anyone in my area to do it, even for good pay.
Don
02-26-2002 20:40:01
 Re: Re: Re: Giving up on Farmall M in reply to redrev, 02-26-2002 06:36:32
Nice looking tractor. I just fixed a M that did the same thing, sometimes worked sometimes not. I bought it and was sitting for 2 years. I took the clutch out throught the belly. Turns out the clutch looked like new, but it was to big in diameter, it was rubbing the fly wheel. I took a sander to the edge and sanded it down just a little and put it back together, works fine now. Clutch disc was just little over sized for some reason. Hope you get it fixed!! Good luck
JPuckett
02-26-2002 17:01:26
Now I have never worked on a M clutch, but a man out the road had a 140 that acted about the same way. Everyone told him the tractor would have to be split. It would up that one of the pins that hold the clutch fingers on had worked halfway out. I was able to fix it through the bottom of the bellhousing. Might be something to check.
The Red
02-26-2002 07:38:33
Have you lenghtened the clutch shaft between the pedal and the lever?
Redrev
02-26-2002 08:43:11
 Re: Re: Re: Re: Giving up on Farmall M in reply to The Red, 02-26-2002 07:38:33
Yup...tried that. A local ex dealer mechanic say it's inside, but he won't fix it for me. Money no longer talks!!!
Mike ISW
02-26-2002 07:26:19
Sounds as though the clutch disc may be in backwards. Maybe!
