Re: F-4 Magneto Disassembly
walt f
02-19-2002 15:38:40
i'll try again to reply to your post. after removing the strap at the top that holds the magnet on, push 2 thin flat blade screwdrivers under the magnet on each side and twist the screwdrivers to lift the magnet up then place larger screwdrivers under the magnet and twist again, be sure to use a lot of penetrating oil to loosen the dirt and corrosion on the sides between the housing and the magnet. you may have to push the magnet down and try again until it comes off easy. go to the top of this site and click on manuals, look for international magnetos... if you need more help, e-mail me...
