Need help determining year of a Farmall H
ROB in NY
02-19-2002 15:23:32
Where is the serial # or any other # that can help me determine the year.
Kurt
02-19-2002 16:09:46
 Re: Need help determining year of a Farmall H in reply to ROB in NY, 02-19-2002 15:23:32
If you look on the tractor, under the gas tank on a plate a # will be there and then look on the YTmag website under serial #s and that will give ya the year.
Steven@nd
02-19-2002 15:29:46
On the left side of the tractor (sitting on the seat) there should be a silver tag on the clutch housing that has the serial number. IF that is gone, there is a machined pad under the number 1 spark plug on the block that also has a serial number stamped on it. Most of the time these numbers match.
Also you can check for casting codes that will be in the format of 10 17 X Where X would be the year. Post back what you find and we will help you out!
Steven
