H Wiring
Hick
07-28-1999 22:59:29
Im restoring a '52 H and I want to put all new wiring on it. Where can I get that kind of wire and all of the harnesses and stuff.
Chuck
07-29-1999 15:10:37
 Re: H Wiring in reply to Hick, 07-28-1999 22:59:29
Hick: I just restored my '50 H and got all the wire harness from Case/IH. It looks and works just great. Also, consider the vinyl decals from Maple and Hunter in Indiana. They look so neat as they come off as individual letters and are simple to apply. Good luck.
Chuck
joe Berendzen
07-29-1999 19:02:24
 Re: Re: H Wiring in reply to Chuck, 07-29-1999 15:10:37
Chuck, Did your harness include the lighting system? And what was the price?
Joe Berendzen
07-29-1999 04:46:12
I cant't say as to whether or not there are any wiring harnesses available for yours. The route I took was to call my local Case/IH dealer and had them fax me a copy of the wiring diagram for my Super M, and I re-wired it. The colors of wire may not be exact, and I used the terminal ends from the auto parts store. It's not a perfect looking restoration, but it all works right.
The Red
07-29-1999 06:48:35
 Re: Re: H Wiring in reply to Joe Berendzen, 07-29-1999 04:46:12
IH still sells them but they are a bit skimpy in length on the older style with the voltage regulator on top of the generator. Like in about 4 inches shorter.
Bill(Tx)
07-29-1999 08:09:34
 Re: Re: Re: H Wiring in reply to The Red, 07-29-1999 06:48:35
Red, could one move the regulator from the gen to the steering post, and use a 12 ga. (or other heavy ga.) wire connector? I've got the old style too, and a new CaseIH (BKen special) harness set. However, I haven't checked the length yet.
The Red
07-29-1999 08:35:45
 Re: Re: Re: Re: H Wiring in reply to Bill(Tx), 07-29-1999 08:09:34
You can. The later style, like originally was on my 51H, had the VR mounted on the rear gas tank support. However I had an extra old style switch and preferred to keep the VR on the generator and out of the weather.
12 gauge would work fine. I had 2 of my Hs wired that way until I stumbled onto Ken's site a year and a half ago.
The Red
07-29-1999 04:37:12
Call Bermuda Ken at 608-455-2411. I get a 10% commission.
