Farmall H Oil Drip from blowby tube
wayne
07-06-1999 13:21:40
I cannot figure out why oil drips from my Farmall H blowby pipe located on the right side of the engine. The drops are faily continuous yet the engine is in otherwise good condition. There is no heavy blowby on the engine and you can feel no pressure when you hold your finger over the hole. Is there a baffle inside or some other feature designed to deflect oil away that is possibly missing or something. I have several H's and this is the only one that does it.
Stan
07-06-1999 15:52:09
 Re: Farmall H Oil Drip from blowby tube in reply to wayne, 07-06-1999 13:21:40
A small amount of blowby is normal for any older Farmall H or M tractor. You may want to check your oil bath air cleaner. It may be plugged internally.
