986 lift problems 3 point
we have had a 986 apart putting gears in tranmisson now we got it all back togeatehr finaly i might add everything works good but the three poit it went up now it want go down and is very spongie any one no what my problem might be acts like it has air in it did we put something on wrong a line backwards or does anyone have any ideal what might be wrong thanks so much for any help
Chris,
It "sounds like" when you set that rockshaft house down on the rear, the draft sensing linkage dropped on the wrong side of the torsion bar finger.
You should be able to go in thru the centerlink mounting boss plate to reverse it.
Allan
which side does it supose to be on and the plate you are talking aobut is the one under the thrid on bracket right thanks so much chris
