Oil For super M
Carl
06-10-1999 01:00:18
Can I use shell Rotella 15 w 40 in my super m farmall,as I have plenty of it on hand..... Thank You.Carl
Dick Davis
06-12-1999 05:24:35
 Re: Oil For super M in reply to Carl, 06-10-1999 01:00:18
Oil has been so much fun, let's talk about gas now!
Secret is out
06-11-1999 19:11:38
Low ash oil is what is used in propane burnin irrigation engines.
Kenenth Updike
06-10-1999 05:30:48
NO! NO! NO! NEVER use a multi weight oil in any IH gasoline powered engine. IH engineered these engines to use ONLY STRIAGHT WEIGHT (30W in summer 10W in winter) OIL. The owners books refer to this, as do the current oil reccomendation from the OEM. These engines do not have the tolerences engineered in them for the use of multi weight oils. Multi weight oils will eventually ruin the engine. IH Gasoline engines preform their best with a low sulfated ash oil. LOW ASH oil sold by IH is what you should use for maximum protection.
Terry Dixon
06-10-1999 20:43:42
 Re: Re: Oil For super M in reply to Kenenth Updike, 06-10-1999 05:30:48
We have used Valvoline 10w30 in our 46 M working tractor, though not so much work for last few years. Been 20 years since first got it and rebuilt engine and there hasn't seem to have been any ill effects on it yet. Regular oil and filter changes over the 20 years has helped more than type of oil I think. Straight or multi, doubt it makes much differance.
Terry
JW BRAUN
06-11-1999 21:02:19
 Re: Re: Re: Oil For super M in reply to Terry Dixon, 06-10-1999 20:43:42
BOY,S REMEMBER THE OLD HARVESTER MOTOR,S DO NOT HAVE A FULL FLOW OIL CLEANING SYSTEM NEVER RUN DETERGENT OIL US ONLY 30-W PUT MY 39 M TOGEATHER 5 YEAR,S AGO AND DO A LOT OF TRACTOR PULLING SPIN THE MOTOR OVER 5000 RPM,S AND IS ONLY A 248 MOTOR MAKES 71 HP HAS NEVER BROKE THANK GOD FFFOR THE IH VALVE CLOSE PINS,HAVE PULLED A FEW RETANER,S
steve
06-10-1999 11:34:53
What tolerances are you referring to? If the engine has lots of oil pressure, obviously the mains and rod bearings are getting enough oil.
The valve train isn't exactly high-precision stuff, either.
An engine is an engine - car, tractor, etc. Tractor engines are understressed (low hp/cubic inch) and run cooler than car engines. Any current oil, multiweight or not, is vastly superior to what was originally put in those engines in the 40s and 50s.
I'd like to know what is magically different about IH engines. (?) I'd rather not start a multiweight/straight-weight oil war, though.
Steve
john
06-11-1999 13:40:44
 Re: Re: Re: Oil For super M in reply to steve, 06-10-1999 11:34:53
We have a cub low boy and an H. The cub tractor required "low ash" oil per the mfgr and dealer. On our H we have used over the years multi weight oil. We figured the tolerances were loose enough to allow for multi weight. However low ash is a good way to go because it will drastically reduce carbon build up in the engine. Same effect for 2 cycle engines.
Bermuda Ken
06-11-1999 10:35:14
The only thing "magical" about IH Low Ash oil is the additives. All of the "multi wieght" oils don't have the same formulation of additives that IH Low Ash has.
IH engineering(not Quaker State, Shell or some other oil co) tested IH engines with both the Brand X and IH Low Ash oil in them. Using IH Low Ash oil, it was noted that the engines burned cleaner and had fewer valve deposits and valve torching(due to the lower sulfated ash content of the IH oil) than Brand X. The Brand X oils don't have the lower ash content that IH Low Ash has.....DUH!!!!! So....Buy what ever you want. It all goes back to the OEM vs Brand X debate. Either stick with what the OEM recommends or pay later. Yes oil is oil, its the ADDITIVES that make the difference, not the price or Brand name.
The Red
06-11-1999 11:40:06
 Re: Re: Re: Re: Oil For super M in reply to Bermuda Ken, 06-11-1999 10:35:14
Interesting Ken. Didn't know that.
Skip
06-11-1999 18:48:40
 Re: Re: Re: Re: Re: Oil For super M in reply to The Red, 06-11-1999 11:40:06
What oil co. Makes the Ih oil?
Kenneth Updike
06-11-1999 19:44:25
 Re: Re: Re: Re: Re: Re: Oil For super M in reply to Skip , 06-11-1999 18:48:40
Viscosity Oil makes the IH Low Ash oil, along with #1 diesel oil, and Hy Tran Plus. Thier oils are not sold at the local X-Mart or Wally World either, only at IH dealers.
The Red
06-14-1999 12:41:05
 Re: Re: Re: Re: Re: Re: Re: Oil For super M in reply to Kenneth Updike, 06-11-1999 19:44:25
Durn Ken, I thought Marvel Mystery Oil made the IH stuff. :)
Miles
06-11-1999 04:47:52
I have been using 10-30 in my 300 since I overhauled it in 1976. If there is problems with multi visc. oils I think it would have shown up by now.
Ludwig
06-11-1999 08:04:34
 Re: Re: Re: Re: Oil For super M in reply to Miles, 06-11-1999 04:47:52
Our Super M has had a sickning variety of oils in it since my Great Uncle bought it in '60.
I personally know about 10-40, 10-30, 5-30(late fall), 10w, 30w, 40w, and ATF(a mistake, but apparently not fatal)
This tractor isn't worked too hard, but hard enough during mowing season when we push through hood high grass with a 6ft mower.
It runs really well, with no smoke and doesn't burn or leak any oil.
The Red
06-11-1999 08:42:40
 Re: Re: Re: Re: Re: Oil For super M in reply to Ludwig, 06-11-1999 08:04:34
All the ATF does is lower your oil pressure but does a heck of a job cleaning out the block.
j.w.braun
06-12-1999 15:46:39
 Re: Re: Re: Re: Re: Re: Oil For super M in reply to The Red, 06-11-1999 08:42:40
yea ATF WILL ALSO WASH ALL DIRT INTO BEERING,S AND RING AREA,DO NOT NEVER USE ATF IN THE MOTOR OIL, THATS SOME OLD WISE TAIL SHOULD HAVE BEEN BURIED WITH THE BUM THAT STARTED IT,WEN I TORE MY 1939 M DOWN THE CRANK WAS OF ONLY .003 TURNED ANYWAY TELL,S ME SOME ONE TOOK REAL GOOD CARE OF MOTOR , GUESS WHAT IT WAS BUILT BEFORE ATF WAS THOUGHT OF. NEVER EVER PUT JUNK IN YOUR OIL,GOOD CLEAN 30 W NO DETERGENT OIL ,FILTER DOSE NOT FILTER ALL THE OIL,REMEMBER YEARS AGO THESE M,S WERE USED AROUND THE CLOCK,I ALSO BUILD DRAGRACING MOTOR,S J.W.BRAUN
Bob M
06-11-1999 10:03:02
Don't forget using ATF also lowers the "available funds balance" in your wallet before it lowers your oil pressure...
The Millionaire Red
06-11-1999 11:42:30
 Re: Re: Re: Re: Re: Re: Re: Oil For super M in reply to Bob M, 06-11-1999 10:03:02
Ouch Bob!
Miles
06-10-1999 02:40:36
Yes, it has the spark ign. rating.
