884 with T/A troubles
Dave
06-06-1999 11:14:40
My father in law has an 884 with a TA problem when the TA is in high it seems to slip or not fully engage. At higher rpm the problem seems to go away.Any answers???
RickB.
06-06-1999 14:58:26
 Re: 884 with T/A troubles in reply to Dave, 06-06-1999 11:14:40
Probably a bad seal in the high clutch pack piston. Will probably get worse, it must be a minor leak now if the pump can overcome it now @ higher RPM's (more GPM's). If it is allowed to slip excessively, the plates will get overheated & warp, requiring their replacement which MAY be avoided if the repair is made now. Could also be a pump or valve problem, don't remember if the utilities have a separate TA pump. Would pay to at least pressure test this system to see what's up.
Dave
06-08-1999 13:40:21
 Re: Re: 884 with T/A troubles in reply to RickB., 06-06-1999 14:58:26
We will have check the things you suggested. It has not been doing this for very long. It is a high use tractor on the farm though, so we don't want it to go too long.
