Re: Can't understand this one----------?
TomH
06-06-1999 05:19:08
Did the gear lube stay in, or do the seals leak? Someone might've drilled/tapped in a grease fitting and filled with grease rather than replacing a leaky seal to keep oil in.
Larry
06-06-1999 12:10:25
 Re: Re: Can't understand this one----------? in reply to TomH, 06-06-1999 05:19:08
I would wager it leaks as Tom questioned and the grease fitting is someones way of assuring the gearbox was lubricated. Feel reassured that at least they were trying to look after the tractor.
