Company Logo Shop Now
Need some engine help guys
Farmallb
03-21-2009 17:51:11
Bought this 49 H. Tried to start it belt to belt off of my CC Case. The H hummed like a sewing machine, and built 40% pressure, but not hardly a pop, and when there finally was a pop, it was soft. I had the mag checked, and its fine. I put a screwdriver into a plug wire and held it close to bare metal and saw fire. I put new plugs in it, and gapped them to 25. Whats your thoughts. The oval box dosent have a knob for light density as my dads 48 had. And, the push pull shitch is mounted in the box instread of away below it. And it has a up/down/ flip switch I dont remember my dads haveing for the mag kill. I think his had a distributor, but that was 50 yrs ago. Sprayed the carb with either but not a pop or nothing. hardly. Havnt done anything yet to the carb. Gonna order a kit Mon
Mike CA
03-22-2009 22:35:28
 Re: Need some engine help guys in reply to Farmallb, 03-21-2009 17:51:11
The internet really brings out the best in people sometimes. :roll: Pathetic.
Farmallb
03-22-2009 14:35:46
Im told this is a 48. The serial number is FBH- 303902XI. Does this tractor have band brakes yet or disc??
rusty wheel
03-21-2009 18:37:40
Maybe low compression. rw
Janicholson
03-21-2009 18:03:17
The switch is not stock. Make sure it is a grounding switch, not power. Timing is everything. I would have you look back in the archives for timing a Mag. Does it have suction on the carb intake when turning? Are you sure you are turning it so the fan sucks air through the radiator (just a thought on the beltup) JimN
Farmallb
03-21-2009 18:39:39
 Re: Need some engine help guys in reply to Janicholson, 03-21-2009 18:03:17
I am 61 ands have been starting tractors that way for 40 yrs. I had a 1/2 twist on the belt makeing both pulleys turn clockwise. Yes, I think the carb had suction, as when I stopped it, the gas/spray would come out of the carb.
gtx1967jewison
03-21-2009 22:39:48
 Re: Need some engine help guys in reply to Farmallb, 03-21-2009 18:39:39
read what u wrote then THINK!!! u had a twit in belt meaning the 2 pulleys HAD TO be turning opposite directions. then u went on to say that the gas sprayed out the CARB when stopped. you're turning the engine backward any way u read it. ha ha lol!
D Slater
03-22-2009 07:13:14
 Re: Need some engine help guys in reply to gtx1967jewison, 03-21-2009 22:39:48
Think he was saying it was showing 40 lb. of oil pressure when turning. It wouldn't have if turning the wrong way.
Farmallb
03-22-2009 10:45:37
 Re: Need some engine help guys in reply to D Slater, 03-22-2009 07:13:14
AND, If it shows 40# pressure, dosent that mean it has good compression?? As to the firing order. I started #1 in the top outside hole, and went around clockwise, 1342
tipper
03-22-2009 21:12:15
 Re: Need some engine help guys in reply to Farmallb, 03-22-2009 10:45:37
I don't think oil pressure is going to tell you anything about cylinder pressure/compression. Is that what you were asking a post back?
This post was edited by tipper at 21:14:10 03/22/09.
Red Mist
03-22-2009 05:43:56
gtx1967jewison said: (quoted from post at 22:39:48 03/21/09) read what u wrote then THINK!!! u had a twit in belt meaning the 2
Wrong. If the two tractors are facing each other, then there has to be a twist in the belt for both pulleys to turn the same way. HAW-HAW.
mike
gtx1967jewison
03-22-2009 22:24:29
 Re: Need some engine help guys in reply to Red Mist, 03-22-2009 05:43:56
haw haw yourself. you're an idiot there CANT be a twist if u want them to both turn clockwise or both turn counterclockwise, i.e. the same direction. obviously its a waste of time trying to fix stupid so PEACE OUT moron. if you were to put a twist in your bicycle chain u think u'd still travel FORWARD when pedaling FORWARD wtf?
Jim Becker
03-23-2009 07:58:21
 Re: Need some engine help guys in reply to gtx1967jewison, 03-22-2009 22:24:29
There is an old saying "Better to keep your mouth closed and be thought a fool than to open it and remove all doubt." Words you should learn to follow. You are forgetting the simple fact that to belt 2 tractors together, one has to face the other. Anybody that thinks about it for a minute would realize that reverses the direction of one pulley relative to the other. Anybody that actually tried to do it would very quickly learn that the twist is needed.
old
03-21-2009 19:49:59
By chance is the firing order wrong??? Could be that the plug wires are not hooked up as they should be
Janicholson
03-21-2009 18:48:51
I believe! The next step after making sure the timing is on, is to do a compression check. Stuck open intake valves, would act like that. JimN
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: POWER BLOCK KIT for John Deere 50, complete with pistons pins and rings new never used. trades welcome. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
