Brakes on a 560 Farmall
Matt
05-19-1999 04:58:45
They work (barely) but one locks up and the other seems worn out. Is changing these a huge job? I'm no master mechanic, and realize that I've got to pull the loader off to do it (frames in the way). I've got the tools and a few friends, but how tough is this, and roughly where am I cost-wise?
RickB.
05-19-1999 15:26:11
 Re: Brakes on a 560 Farmall in reply to Matt, 05-19-1999 04:58:45
Follow all the advice given, then put both new discs & actuator in a drum lying open side up on a bench. Lay a straightedge across the drum & measure the depth to the disc. If it's over .025" then some creative machining must be done to get the proper clearance which will decrease the amount of actuator travel necessary to ensure good braking & releasing. Only test with new discs, as worn ones will require extra machining that will be regretted when the discs are replaced.
Curt Cooke
05-19-1999 05:58:51
Mat, the 560 brakes aren't a big deal in and of themselves. It's the other little things along the way. The brakes, take them apart and clean the actuating mechanisms, replace the disks if necessary (4 of them at about $30 each). The lock up problem could be caused by worn splines on the pinion shaft that the disks ride on, very common on a 560. So the question becomes, where do you stop in your quest to make these right? I don't know the answer but I do know that a 560 without brakes is a an unruly monster.
Wayne
05-19-1999 10:23:55
 Re: Re: Brakes on a 560 Farmall in reply to Curt Cooke, 05-19-1999 05:58:51
Remove and check housings for cracks replace fiber disks and steel ball bearing. Check and clean other parts grease the track the ball runs in. Oh yeah the threaded rod between the pedal and pressure plate will more than likely break.
Matt
05-24-1999 06:43:27
 Re: Re: Re: Brakes on a 560 Farmall in reply to Wayne, 05-19-1999 10:23:55
If the threaded rod breaks, what's this mean? Can it be replaced with standard ready-rod? I haven't started yet, so I'll probably have a better idea when I get started. I think this will be a winter project, as I have to remove the loader/three point to work it over. Can't have the unit down too long at a stretch.
