560 Diesel hydraulics
Gavin Ahlbrecht
06-22-2007 04:58:15
I can't get the 2 pt hitch to lift up or go down. I took the hoses off to repair the hydraulic lines under the seat. I put them back together and no up or down. I am assuming I have air in the cylinder because it is squishy when you stand on it. How do I bleed the air out or fix my problem?
Allan In NE
06-22-2007 05:49:26
 Re: 560 Diesel hydraulics in reply to Gavin Ahlbrecht, 06-22-2007 04:58:15
Do it the easy way.
Lift and lower that hitch 'bout 12 times. The air will eventually work itself out.
Allan
billde
06-22-2007 05:23:32
slightly loosen hoses at the cylinder and cycle the lever a few times to get rid of the air.
