F-20 Front Wheel Bearings
denny in ohio
06-11-2007 11:47:38
Can anyone describe the procedure to remove the wheel bearings from the front hubs of an F-20? I just bought a '38. I found the front right hub is pretty loose. It appears the inner bearing is gone. I removed the nut and lock washer. Inside of that there is what appears to be the race for the bearing, with a pin approximately 1/4 " in dia. sticking out of it. I cannot get movement on that bearing race. It seems awfully solid. It doesn't turn nor will it slide on or off the axle shaft. There is plenty of grease inside and no rust so it isn't rusted in place. What is the next step? Thanks for reading and for any replies.
Nebraska Cowman
06-11-2007 17:32:34
 Re: F-20 Front Wheel Bearings in reply to denny in ohio, 06-11-2007 11:47:38
You are not to the race yet. That piece is threaded.
