Order Farmall Cub Parts Online
Leaking oil on Cub Lo-Boy
Big B
05-10-1999 14:46:13
On the underside of the clutch houseing, there is a circular plate covering a hole. I have been told this is for clutch adjustment. I am leaking oil from this hole, even with the cover on. It leaks bad enough that over a 4 week period, almost all the oil from the crank case was gone. Any suggestions? Will an oil leak stopper help?
Thanks!
Mey('50-Cub)
05-10-1999 17:30:15
 Re: Leaking oil on Cub Lo-Boy in reply to Big B, 05-10-1999 14:46:13
That sounds like the rear engine oil seal. If thats the case, you'll have to split the tractor, remove the clutch, then you can get at the rear seal housing. Mey
