M misses
Rob (Mn)
04-24-1999 23:10:07
I just got a 1950 Farmall "M". It doesn't run too bad but today when I pulled it into the shed I noticed that on each missfire it was shooting flames out through the muffler. Been too busy at work to mess with it very much, but was wondering aside from plugs and timing what should I be looking for as the culpret? PS only had her home now for three days ..
The Red. Been there done that
04-25-1999 03:33:09
 Re: M misses in reply to Rob (Mn), 04-24-1999 23:10:07
Rob you need to set your valve clearances. Sounds like an exhaust valve is not closing or the valve and valve seat are shot. I set mine at .20 when they are cold. Manual will mention .17 when warm. Just make sure you get each cylinder up on compression to adjust correctly.
Bob M
04-25-1999 07:05:24
 Re: Re: M misses in reply to The Red. Been there done that, 04-25-1999 03:33:09
The Red is probably right about valve lash. But before you pull off the rocker box and mess with the valves, check the distributor point gap (should be 0.020) and ign timing. Too small point gap and/or late timing can cause misfiring and flames in the exhaust - and it's easy to correct.
