Farmall 200 / identification/////help!
Bear
04-22-1999 13:26:46
I have a Mckormic Farmall 200 high center tractor
that I am trying to identify Year/and pertinant
engine rebuild PART NUMBERS. The # on the engine plate on the bell housing is 9146J. Can anyone help me with this?
Stan(VA) Its a '55 model.
04-22-1999 13:44:12
 Re: Farmall 200 / identification/////help! in reply to Bear, 04-22-1999 13:26:46
Plate on the bellhousing is the tractor serial number, it shows you have a '55 model. The engine number is stamped on the block just above the distributor mount, but you probably woln't need it. Should be a 123 cu in, 3 1/8" bore, wet replaceable sleeves. Overbore piston/sleeve sets with 3 1/4" bore are available also and more commonly used. Valve train, gasket sets, and bearings are all readily available.
Stan(VA).
04-22-1999 13:43:58
Stan(VA).
BEAR
04-22-1999 19:02:58
 Re: Re: Farmall 200 / identification/////help! in reply to Stan(VA) Its a '55 model., 04-22-1999 13:43:58
Stan(Va), Bear says..... Thanks.Best regards!!
