What Year/Is It Compatible
Tim
04-10-1999 07:18:21
I have a 49' H and have found a Farmall parts tractor. The Ser# is FBH 227092 but the # on the engine block is FBH 201789. What year is this tractor and will the parts be compatible w/ my 49'? I also found the casing stamp 7-24-P if this helps. The engine has thrown a rod. ( BIG hole in block.) So I don't believe much of that will be usable! Thanks, Tim
The Red Again
04-10-1999 09:21:58
 Re: What Year/Is It Compatible in reply to Tim , 04-10-1999 07:18:21
The P casting is 1944. Sounds like that tractor has been put together from 3 H's.
Harold H
04-10-1999 09:37:41
 Re: Re: What Year/Is It Compatible in reply to The Red Again, 04-10-1999 09:21:58
P is 1946
The Red Stands Corrected
04-10-1999 11:47:18
 Re: Re: Re: What Year/Is It Compatible in reply to Harold H, 04-10-1999 09:37:41
Hmmmmm m. Harold I just checked the 45 and it has o's all over it. The 51 has W's all over it, which letters did not get used in between??
Harold H
04-10-1999 21:44:57
 Re: Re: Re: Re: What Year/Is It Compatible in reply to The Red Stands Corrected, 04-10-1999 11:47:18
V was not used.
Jim Becker
04-10-1999 17:19:06
1951 was the disconnect. That year they used both U and W. V was reported as skipped. They started over with A in '55 but did some more skipping.
The Red
04-11-1999 03:09:12
 Re: Re: Re: Re: Re: What Year/Is It Compatible in reply to Jim Becker, 04-10-1999 17:19:06
Thanks. Mystery Solved. My Dang Ol 51 H is relieved. :)
The Red, John Fritz
04-10-1999 08:39:25
Tim you have a 1946 frame and a 1945 motor. You will have no compatibility problems at all. I happen to own and 45 H (200505) and 46 H (228923).
The electrical may be different between the 2 tractors but that is about it. Email me if you have any more questions. Glad to help.
