Funny spark plug wires
RED Blooded
04-07-1999 13:55:05
Anyone ever had this happen,my M is doing somethig wierd.It skips when it is running but if you pull the plug wire out just a little bit,not all the way off,it stops skipping.What is wrong and why does this happen.After a while it stops skipping and runs fine.
Jim Becker
04-08-1999 21:59:54
 Re: Funny spark plug wires in reply to RED Blooded, 04-07-1999 13:55:05
Look up the list a ways for "Anti-Foulers on my M." You are doing the same thing.
The Red
04-08-1999 13:06:40
All you gents are correct. I recommend you go to the new AC C86 spark plug which replaces the C83. I found them at NAPA at $1.60 each or so.
If you are a Champion lover, then I recommend the D-21. Any colder and the Champs seem to not want to fire. I have a whole box of worthless 15's. Learned my lesson.
Phil Auten
04-08-1999 05:12:30
RB,
I had the same problem with my M on Champion D-15 plugs. Fixed it by adjusting the carb correctly (it was way too rich) and then switched to D-21 plugs. Problem solved.
Phil
david
04-07-1999 18:11:41
Pulling the wire partially off causes a voltage increase, thus a hotter spark at the plug which is likely fouled under normal conditions. Look at a different plug or correcting the condition causing the fouling.
Tom V
04-07-1999 14:34:51
I agree with Bob. I had the same thing happen to me with a 1960 Chev. 283. I think your plugs maybe too cold of a heat range and then they tend to "carbon" up. For some reason, when you pull the wires off part way, it seems to get a hotter spark??
Farmall Gray
04-07-1999 15:29:28
 Re: Re: Funny spark plug wires in reply to Tom V, 04-07-1999 14:34:51
It does make hotter spark. Champion even makes
a plug for small engines with an internal gap to
boost spark. I had a tractor that always fouled
1 plug so I took a blown glass fuse and put it
inline between the wire and the plug. That kept
it from fouling.
Bob M
04-07-1999 14:05:46
Your plugs are probably partially fouled due to rich carb or oil burning. Try switching to a hotter set of plugs.
