Creeper gear
lumber4
03-19-1999 11:37:46
Will a cub cadet creeper gear go on a farmall cub Thanks
Ed
Farmall Gray
03-19-1999 16:32:50
 Re: creeper gear in reply to lumber4, 03-19-1999 11:37:46
No. The cub cadet has a gear reduction in front of the transmission, while on the cub there is a
clutch shaft that goes from the clutch in to the transmission and is the upper shaft that the gears slide on. The rear pto will interchange though.
JIM(S.E.OH.)
03-22-1999 06:36:14
 Re: Re: creeper gear in reply to Farmall Gray, 03-19-1999 16:32:50
need more information farmall cub creeper gear bolt on unit? also looking to buy any ideal where app. cost. thank you
