Re: Farmall M Shaft Seals
Dave_Id
01-14-2002 08:24:14
I have bought seals at Napa, Case IH dealership, and a place that speciallizes in bearings and seals. This place was usually alot cheaper than Napa. If you can get the number off the seal, it can be cross ref'd to any number of mfg'r. The seals you get today are about 3/8 thick, where the originals were a combination felt and rubber seal.. The thickness doesn't matter. If your shaft is worn, you can place the seal in an area with no wear.
