Company Logo Shop Now
Re: Fouling spark plugs on 300/450
The Red
01-07-2002 06:07:41
What plugs are you using and what does the end of the plug look like after fouling?
the tractor vet
01-07-2002 07:44:25
 Re: Re: Fouling spark plugs on 300/450 in reply to The Red, 01-07-2002 06:07:41
First thing is to get a good set of plugs in it i prefer MotoCraft or Auto Lite or and AC C86 or 87 off the top of my head i can't remember the other plug no. Then get the tractor warmed up check the timing at idel and at full throttel set the timing to spec. Then idel it down and set low idel then fine tune the air bleed screw for the best low end and keep backing the curb idel screw out till she is running as smoothe as you can get it at the lowest setting then rest the idel screw to spec and look at the exhust and make sure that you have no smoke at idel then set the main at 41/2 turns off the set ,do not force the screw against the seat just so it touches the seat then 4 1/2 turns out . then don.t buy cheep gas put in a higher grade and it will make a differance.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: I NEED A CLUTCH DISC JD PART NUMBER AH800R FOR A H JOHN DEERE LET MEE KNOW WHAT YOU HAVE [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
