Re: Farmall B
Red Dave
01-05-2002 19:06:25
The BN is a varient of the B. The main difference is the rear wheel width. A BN is 8" narrower than a B. The differential shaft housings on a B are 4" longer on each side. This causes a few other differences such as the seat mounting bracket, the pedals are mounted a little differently and the platform is wider on a B.
The engine, transmission, final drives etc are all the same on both. Both were available with a single or dual front wheels.
An easy way to tell the difference between the two is to look at the right side seat mounting, If there is a 4" gap from the seat bracket to the fender, it's a B, if the right side seat bracket is mounted against the fender, using the same bolts, it's a BN.
