Farmall B
Lon
01-05-2002 18:52:43
I just purchased a 1947 Farmall B, I have seen differant information on Farmall B's, and Farmall BN's, can some one tell me if there is any differance in the two tractors...I also have a 1952 John Deere M and have run into the same problem between it and a John Deere MT...Thanks for the help ahead of time
ThatOtherGuy
01-05-2002 21:31:15
 Re: Farmall B in reply to Lon, 01-05-2002 18:52:43
I have a 1946 BN, and the difference is in the rear wheel width. The B is 79 1/2 inches while the BN is 71 1/2 inches. That's all, except some differences in the seat platform as mentioned by Red Dave. The BN is more commly used for belly mowers, because of its tight turning and it was narrower in the rear allowing a 59" mower to do a good mow job while just trailing inside the wheels. The B would look silly with that small of a mower. You bought one of the two because of the ROW WIDTHS. Thats why the C (replaced the B and BN) Has the combined width with a sliding adjustable axle like an H or M. They took the ideas from the B, BN, and bigger ones to form the more versitle C.
Red Dave
01-05-2002 19:06:25
The BN is a varient of the B. The main difference is the rear wheel width. A BN is 8" narrower than a B. The differential shaft housings on a B are 4" longer on each side. This causes a few other differences such as the seat mounting bracket, the pedals are mounted a little differently and the platform is wider on a B.
The engine, transmission, final drives etc are all the same on both. Both were available with a single or dual front wheels.
An easy way to tell the difference between the two is to look at the right side seat mounting, If there is a 4" gap from the seat bracket to the fender, it's a B, if the right side seat bracket is mounted against the fender, using the same bolts, it's a BN.
