Farmall--Super-H-- rear rims
Dan
12-23-2001 13:43:45
Should I buy 10inch or 11inch wide rear rims for my new rear tires??? Tire size being 12.4 X 38-- New tires are Christmas gift from my betterhalf.(bless her)-- I do not know a good brand or place to buy rear new rims for my toy. I am in Minnesota, and I am green as grass at this, any advice would sure help. Thanks in advance for any help. Green Dan in M.N.
Rims???
12-24-2001 09:23:49
 Re: Farmall--Super-H-- rear rims in reply to Dan, 12-23-2001 13:43:45
if your going to buy rims . go to the 12 inchers. you won't be sorry cause the 12.4's will fit and when the tires wear out you can go to 13.6 tires which I did and gives the "H" a whole new bunches of traction which I did on my 3 "H"'s which you'll need. i'm in central Wis inbetween all the clay and marshs.do i have to say any more.
Tom Graham
12-23-2001 17:50:38
Dan, Try Panning Brothers north of Gibbon, 800-635-0993. I bought a new rim for an M for 140 bucks.
Denny Frisk
12-23-2001 16:28:56
My Super H has 11 inch rims with 12.4 X 38 Dayton 23* tread tires. Dayton was an off-brand made by Firestone years ago. Been on the tractor almost 30 yrs now. Firestone still makes 12.4 X 38 4 and 6 ply All Traction Field & Road tires. They would be My first choice. A Friend's Dad just put a pair of new 4-ply ATF&R's on a DC Case for $550 incl. mounting.
The Red
12-23-2001 14:41:38
Dan the 11 inch rims were probably the most common on the Super Hs. The Hs had 9 inch on the early ones with 10 and 11 inch rims used in later production runs. Check with Miller tire for rims. They have the primed/painted rims. A great bunch of folks to deal with!!
