Re: farmall H is fouling plugs
Tom W.
12-22-2001 04:57:16
If your plug fowling is caused by bad rings and high oil usage, you can get non fowlers at the parts store. they screw on the bottom of the plugs and keep the oil off the spark. That is only a temp. fix, but if you only use that tractor once in a while, it will keep you going till you get an overhaul
