Re: 560 head gasket leaking comp on push rod side
the tractor vet
12-11-2001 09:09:35
Todd george is wrigth on the refacing of the head , also with the new head gskt's they have a hard time sealing even after you reface the head. I use spray COPPER COATE on both sides of the gskt and i have found that if you go to the diesel toqure spec. instead of the gas spec. it will seal also re toqure the head with the engine at running temp. I let them run for about and hour at around 1500 rpm.
