706\263\MW pistons
John M.
12-03-2001 20:36:19
Just pulled down a 706g, the block is stamped 263, but sleeve ID is 3 3/4". I assume eng. has M&W sleeves & pistons. What had to be done originally (modified) to install them? What changes in tune up specs,carb,timing, etc. should I look for? who is a good source for replacement sleeve sets? My supplier quoted me $100\a hole, which I think is a little "steep". Thanks
the tractor vet
12-04-2001 15:01:02
 Re: 706\263\MW pistons in reply to John M., 12-03-2001 20:36:19
Your 263 has been update to a a 291 and the sleves that are used have a differnt flange the block has been bored to accomendate the biger sleve. You are commited to go with the 263 to 291 change over ,and yes it will get into your wallet I can't get them much cheeper if you want sticker shock go to Case IH and get a quote from them. But remember your NITRO PILLS>
