Re: Live Hyd Pump
Craig
03-11-1999 19:27:56
The only thing you can check is backlash in the gears, seal and bearings, I would put it on and see how it preforms. You must add a relief valve in the system or you can break the camshaft off the front of motor. Also if you have a M and not a Super M you will probably have to rework front cover and plate or replace them with Super M so pump will bolt up. There are a few late M's with the later front that won't require change.
Stan(VA).
03-12-1999 05:14:22
 Re: Re: Live Hyd Pump in reply to Craig, 03-11-1999 19:27:56
The M&W pump is a more universal fit type and doesn't have the year limitations you speak of for the late model IH pump. I second the relief valve though, heard alot about people breaking cam gears by loading the pump; or just buy and install a heavier cam gear from a later SM-450.
Stan(VA).
