Dist. drive gear timing
Mike in souther
11-24-2001 06:26:30
I removed the dist drive gear from the frt cover before removing cover. After I removed the frt cover and cleaned gears to find crk and cam timing marks I also found another set of timing marks (double punched) on the cam gear and dist drive gear. I have coil ignition and not a magneto. The service manual I have mentions these marks for a magneto but not mine. should marks be lined up with mine as with the magneto ignition? With crk and cam gear marks lined up(which is DTC #1) and the second set of marks lined rotor appears to be at #1 Thanks for any help. Rainy day in WI today
George Willer
11-24-2001 11:41:02
 Re: Dist. drive gear timing in reply to Mike in southern WI, 11-24-2001 06:26:30
Mike,
Lining up the marks correctly is not hard to do. It won't mean much as long as a distributor is used, but will be a kindness to anyone in the future who wants to install a mag. Who knows? It may even be you! Why not do it right?
This assumes you are talking about a Cub.
George Willer
Farmer Bob
11-24-2001 10:06:45
Mike, Should be the same for either Magneto or Dist ignition. Just follow the book you have which sounds like the ITT IH8 Shop Manual.//FB
