Headlights
DC
11-06-2001 18:55:52
Does anyone know the number of a 12 volt sealed beam bulb that will fit the flatback lights used on the 300,350,330 utilitys and others.
jack
11-10-2001 09:31:57
 Re: Headlights in reply to DC , 11-06-2001 18:55:52
The standard trade part number for these is 4511. I purchase my at my local Carquest .
Jim Becker
11-10-2001 15:52:46
 Re: Re: Headlights in reply to jack, 11-10-2001 09:31:57
4511 is a PAR36. 30W, 6.2v bulb. A PAR36 is a bulb with 2 screw terminals. It was used on later tractors after the flat style sealed beam units. The flat style has a single screw terminal in the center of the back. These are not commonly available from general suppliers. reproductions are available from several tractor restoration supply companies. 12 volt versions are available.
Les Repair
11-08-2001 16:55:48
They are made by an aftermarket company. I can get them for you. THANKS
