Re: Farmall 450G Starting
JK MN
03-09-1999 07:52:14
Also check manifold for tightness. Is there a "whistling" sound when it is warmed up and at idle? If it does, there is a leak in the intake manifold circuit, usually where it joins the head. May need a new gasket. May be a cracked intake manifold, that only opens up when warm. Also as you stated, that the gas drips out of the throttle shaft area, there may be a worn shaft and it will allow air to enter and cause poor starting.
JOE
03-11-1999 23:18:55
 Re: Re: Farmall 450G Starting in reply to JK MN, 03-09-1999 07:52:14
I HAD THE SAME PROBLEM WITH MY 400. I FOUND IT TO BE AN OCCASSIONARY STUCK FLOAT. ALSO I WENT THROUGH AND READJUSTED ALL THE GOVENOR POINTS LIKE IT SAYS TO IN THE MANUAL I HAD. WOW WHAT A DIFFERENCE!!!!
GOOD LUCK!
