450? hubs
Author |
J.D.
10-23-2001 12:12:54
Did 450's ever come with 6-bolt hubs? Mine has 6-bolt hubs and rims like the M's and H's. Several archive postings talk about 8-bolt hubs on the 450's. I'm beginning to wonder if mine have been changed at some point. Last question, is there a way to use the rims for an 8-bolt (called double-bevel?) on a 6-bolt hub? Thanks for your help.
Chums5
10-23-2001 18:57:15
Re: 450? hubs in reply to J.D., 10-23-2001 12:12:54
J.D.....No way..won't interchange....if you pull out your rule there's a 1 1/2 inch different between the two....that is your's on the 450 is 1 1/2 inch larger than ones on the "M & H"......hope this helps.....
J.D.
10-24-2001 12:23:28
Re: Re: 450? hubs in reply to Chums5, 10-23-2001 18:57:15
I guess what I meant was, can the double-bevel type be modified to fit the older 6-bolt hubs? I wondered if I could weld spacers around the rim at the six spots where the bolts are located. As it looks, I'll have some time to work on it, four and a half inches of rain in the last week and two more on the way this afternoon here in north-central Indiana.
Denny Frisk
10-25-2001 09:23:59
Re: Re: Re: 450? hubs in reply to J.D., 10-24-2001 12:23:28
IH offered a 9 x 42" tire on the 686 & Hydro 86 Hi-Clears the last year or so them made them. I think the rim was a 7X42 and bolted to the standard cast wheel center(that Your 14X38 Dbl Bevel rims should go on). They had 8 triangular shaped plates welded to the inside of the rim that bolted up solid to the cast center. Proably makes the most sense to do that than to try to modify the clamps. I wouldn't weld on the rims if the tires/tubes are mounted. If there's no tubes in the tires, Tubeless 15.5's were common, take the valvecore out before You weld.
J.D.
10-25-2001 15:00:50
Re: Re: Re: Re: 450? hubs in reply to Denny Frisk, 10-25-2001 09:23:59
Thanks for the info. I'll be sure to put up a post on my success (or failure).
Denny Frisk
10-23-2001 14:34:49
Parts books for the 450 only show Double Bevel rims on the 450's, and the power adjust. The 6 clamp or "DW" style rims ar not interchangable.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Tractor Implements and Their Use - by Curtis Von Fange. Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he reached his early sixties
... [Read Article]
Latest Ad:
WANTED, Minneapolis moline G 955 or G 1355 LP or diesel. Call and let me know what you have for sale.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
