Gas Tank for Farmall A, B and C
Don
10-19-2001 21:06:27
Does any one know if the Gas Tank on the Farmall A and Farmall B fit on the Farmall C Tractor?
Stan(VA).
10-20-2001 19:15:47
 Re: Gas Tank for Farmall A, B and C in reply to Don, 10-19-2001 21:06:27
Well, just for the fun of it I figured I'd toss in another conflicting opinion ;-)
I believe the tanks have the same mounting brackets, but the straight A and B tanks will have the fuel outlet and sediment bowl farther back towards the center of the tank. The Super A and C tanks moved the outlet foward to the front of the tank to clear the touch control assy. In other words, C and Super A tanks would go on the earlier tractors, but the other way around would cause you trouble.
Stan(VA).
J. D. Humm
10-21-2001 14:01:22
 Re: Re: Gas Tank for Farmall A, B and C in reply to Stan(VA)., 10-20-2001 19:15:47
One other thing that threw me a curve- the Super C grille is different from the straight C. It is about 1 1/2 inches to 2 inches taller than the straight C grille. Guess the Super C radiator is a little bigger.
Red Dave
10-20-2001 08:19:26
gene b & J. D. Humm have it right. Same size, different mounting brackets.
J. D. Humm
10-20-2001 07:30:56
If you are looking for a tank for a C be aware that a tank from a Super C is different, also. It's mountings stand the tank up about 1 and a half to two inches taller than a straight C. 200 and 230? (I think) would be the same as a Super C.
gene b
10-20-2001 03:52:47
C mounts different
Redtractorman
10-19-2001 21:30:12
No,The C uses a bigger tank.
ThatOtherGuy
10-19-2001 21:18:39
My answer Is on Case Site.
